I plan to do this to my Ford Ranger 2.3L: Dummy Gauge Fix
The question is, what sender to use. I would like to use most of the gauge sweep. My 2.3L 4 valve engine is specified by Ford to have hot oil pressure at 2000 rpm of 29-39 psi with 5w20 motor oil. I will be using exclusively Redline 5w20. I can get gauge senders in 0-100 psi, 0-80 psi, and 0-60 psi (and lower or higher). I am inclined to get a 0-60 psi so that at road speed it will read up the middle of the gauge. I figure with 5w20 it is not likely to exceed 60 psi or even get that close. If it does, the gauge will be pegged, but would not be ruined (so I am guessing) because the sender will not exceed the stated amount. Thoughts, comments, advice?
I don't have to do this, but it bugs the living whatever out of me to have that stupid fake gauge staring me in the face!
