Originally Posted By: spleeft
Thanks for that great reply !
I will take a pic asap. The Brass jet that protrudes down that you describe sounds correct. Is The flat screw your talking about up inside? There is a hole on both sides , but I assume you are talking about looking up inside from the underneath? And useing the proper sized flat screwdriver to remove the jet, corrrect?
Yes I will drain this time !!
The brass fitting (jet) is up inside the aluminum protrusion. It has a slot in it for removal purposes. You will need exactly the right size screwdriver to unscrew it. Once out, you will see the tiny orifice in the center of it. That's where you need to run the wire/flush and blow out. Don't drop it in the snow.
The hole that will be left after pulling the jet should also be inspected and known to be clear. Flush it with some WD-40 or something similar then blow some compressed air through it. Look again to ensure the passage is clear. Put the cleaned jet back in, carefully install the fuel bowl and gasket, fill with fresh fuel and go get that driveway cleared. Good luck to you.
