dnewton3
Staff member
Last I recall, Blackstone was recommending 20k miles, were they not? It's possible (not assured) you could go the entire year on one conventional OCI. WOW! That would be incredible.
One thing you might consider is to simply run two OCIs per year; spring and fall. You'd be assured you're well within a safe OCI range (approximately 15k miles each), and you'd be under the truck twice. I'm a big fan of getting under there for inspections, and oil changes are a good reason to kill two birds with one stone. Doing them each spring/fall means nice weather, if you don't have a garage to do the OCIs in.
You could run one Amsoil lube/EaO filter cycle for the whole year, and only have one OCI to deal with. But you'd pay 3x+ more money and not get anywhere close to the ROI.
Regardless, congrat's on such a successful dino OCI plan; it's impressive. Given your current mileage, and fantastic success with the VPB, I'd stay the course you're on.
