I know it has been a while since I posted the results, so a quick update on my experience with RP.
I pulled the heads to replace the springs with BeeHive's and did some light porting and polishing (clean up) I also replaced the Comp 127200 NSR's with the Parnelli Jones Comp 127300 VSR Cams. They have at highest lift without removing or limiting the phasers.
Here are some of the pictures( remember this car has 85,000 on the clock)
Porting and polishing
And yes, I did all the work myself...
I have 95,000 miles today so doing my Royal Purple oil change.
My friend's car, the one with the M1 Cams; He spun a bearing on the way back from Carlisle, PA; destroyed both heads, pistons and block as well as the cams. he is in the process of replacing the entire engine but the added cost of heads and cams is delaying the build.
I was able to test the Cams with a micrometer, I took them to the shop where his car is and had them MIC'ed the RP Cams with twice the milage had NO wear at all. We tested against new stock cams (shelf set from ford) and the Micrometer reveiled ZERO wear. yet the M1 cams had a noticable "groove" where the followers touched the lobes on the cam. I had pictures but traded my iPhone 3g for a 4G and forgot to pull the pictures. I will do this again over the winter, the Shop is doing a Dyno tune so I can take full advantage of the Cams.
