2001 Honda Accord (2.3L 4cyl). I'm adding coolant to my resevior but I'm concerned about adding too much. The owners manual is not specific.
Here's my deal: Coolant level (cold) is at the "Min" mark. When Hot, the level is just above "Min". I plan to add enough coolant to bring my level back up to "Max" when cold. Does that sound right? Worse case, a little "too much coolant" would simply vent out anyway, right?
30,000+ miles on the same coolant. No leaks, just evaporation probably. Also spilled a bit from the rad 10,000 miles ago.
Thoughts..
Thoughts..
