I pulled these specs from the M1 data sheets:
Quote:
Mobil 1 5W-30
SAE Grade 5W-30
Viscosity @ 100ºC, cSt (ASTM D445) 11.0
Viscosity, @ 40ºC, cSt (ASTM D445) 61.7
Viscosity Index 172
Sulfated Ash, wt% (ASTM D874) 0.8
HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 3.1
Pour Point, ºC (ASTM D97) -42
Flash Point, ºC (ASTM D92) 230
Density @15.6 ºC, mg/l (ASTM D4052) 0.855
Quote:
Mobil 1 0W-30 Advanced Fuel Economy
SAE Grade 0W-30
Viscosity @ 100ºC, cSt (ASTM D445) 10.9
Viscosity, @ 40ºC, cSt (ASTM D445) 62.9
Viscosity Index 166
Phosphorous (ASTM D4951) 0.065
Sulfated Ash, wt%, (ASTM D874) 0.9
HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 3.0
Flash Point, ºC (ASTM D92) 226
Pour Point, ºC (ASTM D97) -50
Total Base Number (ASTM D2896) 9.1
MRV @ -40 ºC (ASTM D4684) 13,250
Density @15.6 ºC, g/ml (ASTM D4052) 0.842
I'm still learning how to interpret this data, but to my untrained eye, these appear to have very similar viscosities when cold at startup. I find it odd that the viscosity of 5W-30 is lower than 0W-30 at 40C, and the higher VI of the 5W at 172 vs. the 166 VI of the 0W would suggest to me that the 5W would be thinner as well. The only data point that seems to indicate the 0W-30 is thinner at temps lower than 40C is the 3.0 HTHS vs. the 3.1 HTHS of the 5W-30. Can anyone help me make sense of these numbers? How much difference does that .1 lower HTHS viscosity of the 0w-30 make?
Quote:
Mobil 1 5W-30
SAE Grade 5W-30
Viscosity Index 172
SAE Grade 0W-30
Viscosity Index 166
