Opti-4 is the highest quality petroleum engine lubricant available, and is formulated specifically for the severe demands of power equipment.
Opti-4 is a unique blend utilizing patented Eutectic additive technology for anti-wear characteristics combined with the industry's highest standard for anti-corrosion and thermal stability. Through the use of the Eutectic additive, Opti-4 extends the life of any 4-cycle power equipment engine by reducing friction, heat, and wear.
Interlube is so confident in Opti-4's ability to increase performance and extend engine life thru its Eutectic anti-wear additive that when a six-pack of Opti-4 is purchased with a new piece of 4-cycle power equipment, Interlube will Double the engine warranty on internal engine parts. Interlube takes the standard manufacturers engine warranty of two years and Doubles it to four years. Not only is your engine protected from wear, but you are protected from potential costly repairs for an additional two years
ANYONE USE THIS?
ANYONE USE THIS?
