Daryll
Thread starter
Originally Posted By: CapriRacer
Originally Posted By: Daryll
I'm not sure what you said, but: it appears that, in the winter, my tires show pressure going up 3 lbs from sitting outside, cold, to being driven after a good warm up. 5 pounds in the summer.
My rule of thumb is that normal driving should see AT MOST a 3 psi build up. I would be concerned if I saw more and I would add pressure if I saw 5 psi.
Based on that, Daryll, I think you aren't using enough pressure.
Actually, I overinflate my tires a little so that's not the problem. Truthfully I don't remember for sure how much the increase was, in the summer, from cold to hot. I'll be sure to find this out next summer. But I am seeing 2-3 pounds, max increase now (Pittsburgh fall/winter), assuming a constant temperature outside from cold to warmed up tires.
