This is the PDS from WPP from March for ST HM 10W40 SN oil.
It is different than the VOA here.The VOA here may noy be right,Blackstone has had wrong readings before and this one might be wrong too.
10W-40 HM
Physical Specifications
Procedure Test Min Max Typical Results
ASTM D4052 Specific Gravity at 60̊F NA NA 0.8725
ASTM D287 API Gravity NA NA 30.68
ASTM D445 Viscosity at 100̊C, cSt 12.5 ASTM D445 Viscosity at 40̊C, cSt NA NA 109.70
ASTM D2270 Viscosity Index NA NA 150
ASTM D1500 ASTM Color NA NA 2.5
ASTM D5293 Cold Cranking Simulator, cP NA 7000 6757
ASTM D5185 Zinc, % mass NA NA 0.085
ASTM D4951 Phosphorus, % mass 0.06 NA 0.072
ASTM D5185 Calcium, % mass NA NA 0.214
ASTM D5185 Molybdenum, % mass NA NA 0.008
ASTM D5185 Boron, % mass NA NA 0.023
ASTM D4951 Sulfur, % mass NA NA 0.341
ASTM D5762 Nitrogen, % mass NA NA 0.102
ASTM D874 Sulfated Ash, % mass NA NA 0.92
TM
High Mileage 10W-40 API Performance SN
