Ground effect
by mjoekingz28
02/13/16 04:36 AM
20w50 thick? i present to you Penrite's 50w70!
by FordCapriDriver
02/13/16 03:46 AM
08 caravan / oil seeping from spark plug
by Mark72
02/12/16 11:25 PM
Holley Accelerator pump probem
by nwjones18
02/12/16 10:56 PM
Sealant for threaded air hose fittings.
by BigD1
02/12/16 10:37 PM
on line data search programs - which is best?
by bmwjohn
02/12/16 10:11 PM
What size air compressor is needed
by ram_man
02/12/16 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
02/12/16 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
Left my lights on and battery died.
by joegreen
02/12/16 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
02/12/16 07:18 PM
wdleighton1, RTS, jhmed80, engus, Rob_Pol
56902 Registered Users
17 registered (1foxracing, dmdx86, Char Baby, Ifixyawata, dec219644, bbhero, 2 invisible), 468 Guests and 93 Spiders online.
56902 Members
66 Forums
244628 Topics
Page 1 of 2 1 2 >
#2451911 - 12/03/11 12:16 PM Understanding VW oil specifications
dparm Offline
Loc: Chicago, IL
Can someone please verify this website is correct?
http://www.oilspecifications.org/volkswagen.php
It's actually saying that 504 superseded 503.01, the old "high performance" oil spec. The way I understand it is that 504 oils can be used on anything that calls for 502, but not the other way around. 504 does not technically "supersede" 502 but rather "supplements" it. The Lubrizol graphing tool shows 504 being stricter than 502 (and also placing emphasis on fuel economy).
Lubrizol's site actually shows that 502 was revised in 2005, wheres 504 was revised in 2004. VAG is still selling cars that call for VW 502 oil, like the new S4.
2011.5 BMW M3 saloon ZCP
Castrol Edge Professional TWS 10w60 + Mahle OX 254D3
#2451936 - 12/03/11 12:59 PM Re: Understanding VW oil specifications [Re: dparm]
Quattro Pete Offline
Loc: Great Lakes
I suspect the difference between VW 504 and VW 502 is similar to the difference between BMW LL04 and BMW LL01. The first one (504, LL04) is typically a mid/low-SAPs oil (for aftertreatment compatibility) which is incapable of extended drains when gasoline quality is sub-par, like is the case in the US where our gasoline isn't ultra low sulfur.
That is why something like LL04 superseded LL01 in Europe, but it did not supersed it in the US.
This thread has some additional discussion on the subject:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1923428#Post1923428
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#2452315 - 12/03/11 09:19 PM Re: Understanding VW oil specifications [Re: dparm]
glxpassat Offline
Loc: Huntsville, AL
Since 504 meets higher specs than 502, a lot of cars don't need it. Anybody could use it, but it costs more and 502 is fine for most.
#2452602 - 12/04/11 09:10 AM Re: Understanding VW oil specifications [Re: Quattro Pete]
UG_Passat Offline
Loc: NJ
the exhaust aftertreatments is more for the diesel side of things, 507 vs 505/506, but it is basically the same as 504
back to 504 vs 502.... of course, it's restricted to 5w30 only AND the starting tBN is also a lot lower, something to consider vs 502, and the sulfur in the fuel
#2452726 - 12/04/11 11:21 AM Re: Understanding VW oil specifications [Re: dparm]
rg200amp Offline
Loc: Phila,PA
Whatever your VW/Audi calls for = what you should use.
/thread
approved
// 2013 Subaru WRX //
SOLD:
-11 Volkswagen Jetta
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
#2453495 - 12/05/11 06:15 AM Re: Understanding VW oil specifications [Re: rg200amp]
UG_Passat Offline
Loc: NJ
/thread
approved
Ironically, 505.01 is not an acceptable oil for the PD engines with fixed OCI's. This was the recommended oil for north america AND led to premature wear on the camshafts which drove the PD injectors. HDEO is a better choice
#2453559 - 12/05/11 08:16 AM Re: Understanding VW oil specifications [Re: rg200amp]
dparm Offline
Loc: Chicago, IL
/thread
approved
Yes, thank you.
I am merely interested in understanding all the different oil specs. I'm fairly comfortable with selecting oils for my own motor.
#2453607 - 12/05/11 09:02 AM Re: Understanding VW oil specifications [Re: dparm]
UG_Passat Offline
Loc: NJ
http://www.oilspecifications.org/volkswagen.php -- it's basically correct in the short story.
502.00 was originally a mid-SAPS oil that was restricted to primarily 5w40 (with some 0w40 in there) weights only.
the revision to 502.00 opened up the multi-viscosity ranges AND allowed Low-SAPS to join the mix & overlapped 505.01 requirements also. Prior to that, 505.01 was its own oil (ie Castrol TXT 505.01)
when the C5 RS6 was available for the US market around 2004, technically, required 505.01 with ridiculously short OCI
#2453615 - 12/05/11 09:08 AM Re: Understanding VW oil specifications [Re: UG_Passat]
Loc: Great Lakes
Interesting. What is the source of this info?
I thought the concept of mid-SAPs oils didn't even exist back in 1997 when the 502.00 spec was created...
#2453677 - 12/05/11 10:30 AM Re: Understanding VW oil specifications [Re: dparm]
UG_Passat Offline
Loc: NJ
vw502.00 was revised early 2000's before the 2005 revision
#2453727 - 12/05/11 11:47 AM Re: Understanding VW oil specifications [Re: dparm]
Loc: Great Lakes
Thanks, but you didn't answer my question. smile
#2454157 - 12/05/11 07:25 PM Re: Understanding VW oil specifications [Re: dparm]
UG_Passat Offline
Loc: NJ
vw 502.00 specifications have a tendency to align with acea a3/b4 requirements
vw 502.00/505.00 (back when I had a 02 tdi), the appropriate acea a3/b4 revision was 1998 year which was mid-saps
acea a3/b4 with the 2004 revision introduced low-saps
1996 was probably high saps
#2458582 - 12/10/11 07:46 AM Re: Understanding VW oil specifications [Re: UG_Passat]
BobFout Offline
Loc: Indiana
/thread
approved
Except for the PDs that used 505.01 only and didn't fail, the ones that used 505.01 only and did fail, the ones that used HDEO 5w40 only and didn't fail, and the ones that used HDEO 5w40 only and did fail.
2003 VW Jetta TDI / 2015 VW GTI 2.0T
#2465320 - 12/17/11 10:01 AM Re: Understanding VW oil specifications [Re: dparm]
pavelow Offline
Loc: Orange Park, FL
VW/Audi and their oil specs are ridiculous to say the least, but if you own one of these cars, they are a necessary evil you have to deal with. In this day and age it seems almost snobbish to have them. lol
06 Pontiac GTO LS2
08 Chevy TrailBlazer SS LS2
#2465491 - 12/17/11 01:09 PM Re: Understanding VW oil specifications [Re: pavelow]
91344George Offline
Loc: CA
The reason they need them, especially in the US, is because of the generally lower quality of most oils.
Page 1 of 2 1 2 >
