An oil that meets VW gasoline and diesel specs?
San Francisco, CA
Hey guys,
After much research, it seems there is only a two oil alternative but is there an oil on the market that meets both the VW gasoline engine specs 503/505 and VW diesel 505.01, 504/507?
Doesnt M1 ESP 5w-30 meet the latest VW gas and diesel specs? The latest ones supercede earlier ones.
Beware of running low SAPS in ga$$ers though.
Originally Posted By: BMWTurboDzl
Plus the M1 meets ACEA A5 with a HTHS over 3.5!
Just to be clear, it meets engine test requirement stipulated in ACEA A5, but it doesn't actually meet the whole ACEA A5.
True and I think it's impressive. I ran this oil during a summer and I had ~2 mpgs better mileage over the Castrol SLX OE of the same weight. If the M1 was as cheap as the SLX I'd use it every time.
Originally Posted By: Flying_A
Hey guys,
gas specs:
502
503
504
diesel specs:
505
506
507
usually, you'll find something that meets 502.00/503.01/505.00/505.01 or 504/507
which one are you looking for?
Hey guys,
gas specs:
502
503
504
diesel specs:
505
506
507
I see... Just something that more or less meets both the gas and diesel specs for 2009 and older vehicles. To clarify, I assume the 504 and 507 are the latest and greatest specs from VW?
Originally Posted By: pavelow
Shell Rotella T6 5W40 possibly?
I'm sure it would perform admirably in most applications but not approved by VW for any of the above specs.
Hey guys,
gas specs:
502
503
504
diesel specs:
505
506
507
09 or older means you want 504/507 which you can buy mobil 1 ESP 5w30 in stores
Hey guys,
gas specs:
502
503
504
diesel specs:
505
506
507
Noticed a typo finally... it should be 09 or newer => 504/507
