whole hog cook w/ pics
by 04SE
18 minutes 57 seconds ago
redo a/c in 1994 dakota 2wd
by bmwjohn
53 minutes 21 seconds ago
How to post UOA's on here?
by motor_oil_madman
56 minutes 34 seconds ago
Remanns Brand Remanufactured engines
by TiredTrucker
Today at 09:11 PM
Best long lasting door hinges lurbicate ?
by MetalSlug
Today at 08:59 PM
How do you clean trunk area (not inside the trunk)
by MetalSlug
Today at 08:57 PM
Gas prices do the ol' switcheroo
by grampi
Today at 08:44 PM
Possible Valve adjustment needed?
by andrewp1998
Today at 08:16 PM
Hey Dad, can I have some corn syrup, corns starch
by Shannow
Today at 06:47 PM
Idling question
by thunderfog
Today at 06:39 PM
Lodge Sportsman Grill
by hatt
Today at 06:07 PM
2016 Honda Civic factory filter, CUT OPEN
by car51
Today at 05:34 PM
LatitudeDancer, AKN, NickGB, Marcusd1979, emar520
58644 Registered Users
74 registered (AirgunSavant, AZjeff, 2015_PSD, 04SE, ActiveWolf, ag_ghost, 4 invisible), 1575 Guests and 8 Spiders online.
58644 Members
66 Forums
252423 Topics
Page 1 of 2 1 2 >
#2455048 - 12/06/11 05:26 PM 2006 Accord, 4 cylinder code P0420
greenjp Offline
Loc: Germantown, MD
The wife's 2006 Accord with about 55k miles on it just turned up code P0420 today, catalyst efficiency below threshold (bank 1). A little research indicates this probably means either the post-cat oxygen sensor is bad, or the sensor is fine and the cat itself is actually going bad. Any thoughts on those, how to check, etc?
Also, am I correct in believing this ought to be covered by the mandated extra warranty on the emissions control system? Thanks,
jeff
#2455056 - 12/06/11 05:31 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
JRed Offline
Loc: Virginia
Might be covered by emissions warranty, might not.
Probably a bad O2 sensor unless your engine has other fairly obvious problems.
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2455057 - 12/06/11 05:31 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
HTSS_TR Offline
Loc: Lake Forest, CA
Emission system is covered with 10 years 100k miles warranty.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2455078 - 12/06/11 05:43 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
Bill in Utah Offline
Loc: UT
2006 is it not 8 years or 80,000 miles unless you live in one of the "other" states like CA, NY, NJ and such? And those states depends on if its a PZEV and such rated vehicle.
I'm pretty sure 8 years or 80k. Take it to the dealership and let them figure it out since you are under either number.
Pretty early to see the emission codes popping up...
Bill
#2455090 - 12/06/11 05:55 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
Trav Offline
Loc: MA, Mittelfranken.de
Don't do or change anything, you could end up on the hook for the repair. As Bill said go to the dealer and let them worry about it.
#2455117 - 12/06/11 06:23 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
beast3300 Offline
Loc: Ohio
I thought it was 8/80, go to dealer.
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#2455195 - 12/06/11 07:31 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
Tegger Offline
Loc: Canada
You are correct. The federal EPA warranty is 8 years or 80,000 miles, whichever comes first. That's a ONE-TIME ONLY warranty, so subsequent cats are subject only to the maker's own warranty. This is explained in detail on the EPA's website.
It's not the downstream oxygen sensor, so forget about that idea. Unless there's an exceptional issue, the cat is simply bad.
You MUST insist the dealer check for TSBs for your vehicle and P0420 DTCs. They are unlikely to check on their own, and you'd be surprised what can lead to a P0420 that originally had nothing to do with the cat. I have a page on my site where I compiled a list of TSBs outlining problems that led to cat damage, and needed to be corrected before the cat was replaced. See at the bottom of this page:
http://www.tegger.com/hondafaq/p0420/index.html
If you've been careless enough to allow the car to run out of gas once or twice, or to have driven for extended distances with a very low fuel-level, don't tell the dealer. That is considered abuse, since it causes substantial damage to the cat, and it may complicate the warranty claim. There are warnings about such behavior in your Owner's Manual.
Finally, DO NOT HAVE AN AFTERMARKET CAT INSTALLED, and DO NOT allow an independent shop to work on the car for this issue. Those would be the WORST things you could do right now!
Edited by Tegger (12/06/11 07:33 PM)
2013 Toyota RAV4 - 55,000 miles - Toyota 0W-20, Toyota filter
#2455237 - 12/06/11 07:58 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
artificialist Offline
Loc: Florida
Go to the dealer and be quick about it.
When a cat located near the cylinder head fails, sometimes it gets sucked back through the exhaust valve and abrades the piston rings and bores to death. This frequently happens to 2.5L Nissan engines.
2010 Lancer Ralliart Sportback
#2455397 - 12/06/11 11:11 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
L_Sludger Offline
Loc: NORTHCOM AOR
Go to dealer OR install two spark plug anti-foulers in series into the O2 sensor bung after the catcon and then screw the o2 sensor into there. that'll take care of the p0420 code
#2455506 - 12/07/11 06:52 AM Re: 2006 Accord, 4 cylinder code P0420 [Re: Tegger]
greenjp Offline
Loc: Germantown, MD
Great info everybody (tegger especially), thanks a lot. There is one service bulletin for this type of car, relates to an ECM problem where it incorrectly interprets sensor inputs and throws this code. It's listed for the '03 4 cylinder Accord so it may apply. Either way it sounds like I ought to get it to the dealer.
jeff
#2455884 - 12/07/11 02:39 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
Vikas Offline
Loc: NorthEast
The TSB most likely relaxes the ECM criterion to throw the code. However, if the cat has really died, the code will come up again, hopefully before 8/80K is up.
Forget about the anti-fouler for this vehicle; this is a manufacturing defect and it will be corrected by the manufacturer.
- Vikas
#2462069 - 12/14/11 07:17 AM Re: 2006 Accord, 4 cylinder code P0420 [Re: Vikas]
greenjp Offline
Loc: Germantown, MD
Minor update - the CEL went out yesterday. The code is still stored but no light. No pending codes either which is different from before.
A week ago I reset it and it came back on pretty quickly, so I'm curious to see what happens next. Still planning to take it in to get looked at in a couple days.
I noted that something similar happened a few years ago on my 2003 Saab. Got P0420, cleared the code, and it never came back. That car is at 157k miles and every piece of the exhaust is original.
jeff
#2462648 - 12/14/11 05:06 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
Vikas Offline
Loc: NorthEast
If yours is under 8/80, why did you reset the code?
#2463101 - 12/15/11 06:15 AM Re: 2006 Accord, 4 cylinder code P0420 [Re: Vikas]
greenjp Offline
Loc: Germantown, MD
I know from past experience that many codes will simply never come back, indicating that there was a non-existent or very marginal problem. So that's usually my first trouble shooting step. Like I said, on my Saab this very code appeared once, I cleared it and it never returned. That was almost 3 years and 50k miles ago.
With this occurence on the Accord, it came back very soon after clearing it. Stayed on for about a week then the CEL turned off by itself. I checked and the code remains stored.
jeff
#2463329 - 12/15/11 12:02 PM Re: 2006 Accord, 4 cylinder code P0420 [Re: greenjp]
Vikas Offline
Loc: NorthEast
If you get past the warranty period, this repair will cost you four figures. I understand your concern about visiting dealer but in this particular case, it is warranted (sorry for the pun).
I really wish somebody had put some sense in to me when my Honda was doing similar things. By the time I realized about federal emission warranty of 8/80K, the van had already crossed that mileage. I used to reset the code but it used to randomly pop back. It first started when the van had under 60K miles.
You have to take my word but when it comes to P0420/P0430, you are not going to find anybody who is more knowledgeable than me :-) OK, I am half kidding!
- Vikas
Edited by Vikas (12/15/11 12:03 PM)
Page 1 of 2 1 2 >
