Do you see a significant drawback to installing an aftermarket ATF cooler and completely bypassing the cooler in the radiator? The OEM setup, even with the additional cooler for towing, runs in series with the cooler in the radiator.
Our MDX has 75,000 miles on it now and it's getting to the point where cooler failure in the radiator is getting more likely. That nearly instantly ruins the transmission. This is an extremely common problem on MDXes and Pilots. Taking the weak internal transmission cooler out of the equation removes the main variable with transmission longevity on the 2004+ MDX/Pilots.
I'm thinking that an external cooler, especially in our fairly moderate-to-warm climate, won't hurt anything. If I lived in Michigan and routinely drove in sub-freezing weather it might be an issue, but as I see it the only thing I could lose here is a touch of efficiency with "thick" ATF (which is awfully thin anyway). I do know the stock cooler will actually act as a warmer in cold weather, but again, I don't see a huge drawback in our moderate climate down here.
My other option, obviously, is replacing the entire radiator, but that's a more invasive (and costly) procedure that I'd rather not do if I don't have to.
What do you think?
What do you think?
