Originally Posted By: Rhymingmechanic
If stop leak won't stop the leak, an expandable rubber plug might be a solution if you can get the leaker out. (I'm sure there's a real name for the part, but I can't think of it. It's a thick rubber plug with a nut that expands the plug when tightened.)
I once bought a Caprice police car with 150,000 miles on it, and some freeze plugs were leaking. One was a bear to get out even with a bent homemade chisel/punch contraption, and there was no way to install the new one without pulling the engine. I put in one of those rubber plugs and just snugged the nut down now and then for the next 50,000 miles.
Yeah, the engine would probably have to be disconnected from the transmission and lifted up at the minimum.
So, I got to thinking that the engine started leaking with ~800 miles on it... Why should I pay for the stop leak? It wasn't my work that failed, nor did I have a hand in it. So this afternoon over lunch I went to the parts house/machine shop that did the work and hit the manager up about it. I asked what the warranty was - 12mo/12k miles. Well, the work was done nearing 2 years ago... So even though he really didn't have to do anything, he offered to stand behind his machinist's work and buy the GM cooling system tablets for me.
This reaffirms my belief that being a good customer pays off. I do the bulk of my business with them and try to be a pretty agreeable fellow, even when things don't work out right and thankfully they reciprocated...
Now, that being said, I checked the leak again tonight and it seems to be gumming up so I think I'll just add 2 tabs for now.
