And I'm not referring to the missus...
My 15 year old Maytag undercounter dishwasher went from washing dishes fine to barely washing them in a period of about 6 months. I also noticed that there was a light white transparent coating that started to build on my glassware as the cleaning quality went downhill.
Last night, I started in to figure out the problem. And it only took about 10 minutes to find it.
With my Maytag, there is a circular plastic water filter under the cover that the lower spray arm is mounted to. This filter is about 2" tall, and about 8" in diameter.
It was nearly completely plugged with white deposits. I would assume that most of these deposits came from the water supply (calcium/lime) and possibly from undissolved dish detergent. I run hot water in the sink before firing up the dishwasher, so I would assume that mine was mostly from the water.
I removed the filter and soaked it in straight white vinegar.
After a good long soak in the white vinegar, I scrubbed the filter with a plastic bristle scrub brush, then used compressed air from the air compressor on it. I'd say I was able to remove about 90% of the deposits.
I read to run the dishwasher for a few cycles with 1 cup of white vinegar in it (with no soap or dishes). After a few cycles, I can tell that it is circulating water better each time I run it, just by the increased noise level of the whooshing of the water when it runs.
I'm going to pull the filter again in a few weeks, just to make sure that it hasn't caught a bunch of crud that the vinegar has cleaned out of the system.
Also read that the quicker buildup of the white crud is a result of the removal of phosphorus from dish detergent.
Just thought that this might help someone else out as well.
