So if I want to have exactly 30 LBS in my tires when they are "cold". My internal garage is 55 degrees but the outside temperature is 25 degrees. The car has been sitting overnight in the garage. How much more than 30 lbs do I put in so that when the car is outside in "operating temperature", the cold pressure, before driving, will be 30 lbs?
I've experimented with this a little and it SEEMS that the answer is 2.5 pounds. Meaning put 32.5lbs into the cold but garage car would be the same as 30lbs if the car was out all night in 25 degrees.
Does this sound right?
