Originally Posted By: dnewton3
Originally Posted By: chevrofreak
The only reason to reset it is to oil it. It isn't going to hurt a thing if you don't.
Completely and utterly correct.
Think about the "normal" firing mode ...
Pull trigger, trigger is held back, slide cycles full rearward and then forward to slide lock, you then reset trigger for another fire sequence if desired. The connector is cycled by the slide ramps.
The only thing "different" about the field strip is that after you pulled the trigger and held it back, the slide didn't stop at the lock, as you assisted it in coming off the frame. Then, when time to reassemble, you cycle the slide all the way to the rear, and then it moves back into battery at the slide lock, just as it would in a "normal" firing sequence.
The position of the connector does not matter; it gets reset when the slide goes past.
Not sure that I disagree about the need of the trigger bar being reset for field striping, The armor's course is very clear about the bar being put in reset for reassembly.
the connector does not move "per say", but the trigger bar is definitely not thrown above the catch on the connector (reset) when the slide goes past it.
