TBN for Oil Change
by Gene K
7 minutes 16 seconds ago
Why Even Stop?
by AirgunSavant
7 minutes 39 seconds ago
Pirelli Cinturato Strada
by 3for3
14 minutes 51 seconds ago
Oiled air filters better?
by paulri
20 minutes 56 seconds ago
Transmission fluid change gone wrong!! Help
by Sixxer
25 minutes 28 seconds ago
K&N HP-1002 & Fram PH3614
by Recalculating
Today at 11:22 AM
Long hauls = go full synthetic?
by Run
Today at 11:02 AM
Napa conventional oil $2.19/qt
by slacktide_bitog
Today at 10:56 AM
Fiesta ST 5W30
by Pepsibottle1
Today at 10:48 AM
More destruction ahead?
by andrewg
Today at 10:17 AM
Sticky intake valves
by Ozzmosis
Today at 10:11 AM
2003 Ford Explorer Sport XLT Differential Fluid
by TalNum
Today at 10:03 AM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
97 registered (3for3, AandPDan, 2002 Maxima SE, 2cool, 2015_PSD, 8 invisible), 2026 Guests and 311 Spiders online.
57758 Members
66 Forums
248302 Topics
Page 1 of 2 1 2 >
#2450624 - 12/01/11 10:55 PM How not to highside?
mjoekingz28 Online   content
Loc: The Stack in Rankin County
I had a mishap at the track some time ago and could never figure out why what happened did happen.
So you're at a good lean angle and you either hit a wet spot or give to much throttle and the rear begins to slide. I know you DO NOT let off the throttle or you'll flip. What do you do to safely and accurately regain the traction.
My experience:
It had just rained a few hours before and the track was partially wet/dry. I rounded going around a long sweeper and the rear was slightly out and I just held it like that through the wet turn. Just thinking to myself "this is cool", when all of a sudden I hit a dry patch, the rear caught and the bike stood up and sent me to the ground. I tried to catch myself when hitting the ground by using my arms in a push up position. This broke my elbow.
It was in 2005 and I would just love to actually learn something from it.
two for two wheel Tuesdays
#2450656 - 12/02/11 12:34 AM Re: How not to highside? [Re: mjoekingz28]
Radman Offline
Loc: Detroit, Michigan
Six years ago and you are just now thinking about this?
This depends on the track and the tires.
In mixed conditions sliding can either put you in the front or on the ground. Experience and instinct is how a racer decides. Mixed tracks I took it conservative. Not to say I never pancaked a bike before.
2006 Maxima 120K M1-105, M1 0W40
2006 Sentra 90K M1-105, GTX 5W30
2010 Altima 20K M1-105, GTX 5W30
2013 Yamaha FZ1 1K PL1410, SRT5 15W40
#2450782 - 12/02/11 08:35 AM Re: How not to highside? [Re: mjoekingz28]
boraticus Offline
Loc: Canada
"Six years ago and you are just now thinking about this?"
Post traumatic stress disorder or.... just got out of the hospital?
I heard of a guy who had been injured in an auto accident. When he came out of his coma, the only injury that he thought he had was his broken leg. Head injuries sometimes just don't register with those afflicted.
#2450809 - 12/02/11 09:19 AM Re: How not to highside? [Re: mjoekingz28]
BigCahuna Online   content
Loc: Deep in the heart of Jersey
I'm betting he's thinking of going back to the track and doesn't want to make the same mis-que again.I can't understand why they let racers race on wet roads. You know what's about to happens when the rooster tails start flying.,,,
#2451648 - 12/03/11 12:40 AM Re: How not to highside? [Re: mjoekingz28]
Riding in the rain, my guess, is a valuable training scenario. The track 'referee' wouldn't let me go out in the rain, but waited an hour and let us on a damp track. 2-3 sessions in and I was down.
There was no head impact, but thats not to say there are no lingering injuries.
You know Radman, I never got any closure. I thought I was in control and as soon as you think that,,,,,,
I've considered enrolling in a physics class to fully understand what/how/when/where the forces interacted with all the factors (steering angle, lean angle, traction, etc.)
#2451769 - 12/03/11 08:48 AM Re: How not to highside? [Re: mjoekingz28]
boraticus Offline
Loc: Canada
Let's try to look at the mishap analytically.
You were racing on a damp track and your rear wheel began to spin due to compromised traction. The wheel is spinning because the moisture on the track is not allowing the rubber and pavement to make good contact. Accordingly, when you rear wheel made contact with dry pavement, it would have made much better adhesion to the point where it would be similar to the wheel contacting an immovable object. The sudden adhesion would cause the bike to stand up and possibly hi-side. In your case it did. The only way that I could imagine to avoid a high side would have been to stay hard on the gas and continue the wheel spin until you're out of the turn and the bike is in an upright position.
This is just my perspective of what might have happened. I'm not a racer so, I might be completely off base.
I encountered a similar situation while riding back roads but with sand in a curve and relatively slow speeds (50-60 mph). Fortunately, once the bike got out of the sand and back onto clear pavement, it just snapped upright and it didn't go down.
#2452067 - 12/03/11 03:41 PM Re: How not to highside? [Re: boraticus]
OtisBlkR1 Offline
Loc: Indiana
PERFECT REPLY: the only way you could stay on the gas and not highside in this situation is to absolutely stand on the throttle just before hitting that dry spot with a combination of also starting to stand the bike up. if you had the wheel spinning at a extreme rate you might be able to dance through the patch.. Ive seen many high/low sides at the track,ON the track, and on video,. The example you gave is one of the very worst situations you could find yourself in.. I dont like wet/damp tracks for just this reason.
There's a reason you see way, way more crashes durring AMA/SBK/MOTO-GP wet races, if the best in the world experience these problems and cant overcome them.. chances are you and i cant either.
06 Silverado 88,xxx Mobil 5-30
11 Acura MDX 49,700 Valvoline syn blend
06 Milan 49,000 PP 5-20
12 Polaris Ranger 800XP 04 RAPTOR 660 06 SUZUKI Z400
#2452072 - 12/03/11 03:47 PM Re: How not to highside? [Re: OtisBlkR1]
KernelK Offline
Loc: PA
Yup.
#2452549 - 12/04/11 07:30 AM Re: How not to highside? [Re: mjoekingz28]
Smoky14 Offline
Loc: Nowhere NM
I've considered enrolling in a physics class to fully understand what/how/when/where the forces interacted with all the factors (steering angle, lean angle, traction, etc.)[/quote]
Having raced, studied physics, and crashed it comes down to "some days you get the bear, somedays the bear gets you".
Guys in MotoGP high side and low side. Those that recover are good, but most times LUCKY. Racing MC can hurt, stay on the rubber for best results.
Smoky
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
#2456053 - 12/07/11 05:40 PM Re: How not to highside? [Re: Smoky14]
Doog Offline
Loc: North Coast
Originally Posted By: Smoky14
Having raced, studied physics, and crashed it comes down to "some days you get Sir Isaac Newton, somedays Sir Isaac Newton gets you".
Here I fixed it for you...... laugh
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#2456098 - 12/07/11 06:14 PM Re: How not to highside? [Re: Doog]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
That pretty much says it.
The only sure fire way to avoid highsiding on a bike when well banked is to not drift or slide particularly on pavement. I could say use extreme concentration reading the road condtion for changes in grip level but you should be doing that anyway and it's still no guarantee.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#2456639 - 12/08/11 07:39 AM Re: How not to highside? [Re: Doog]
Smoky14 Offline
Loc: Nowhere NM
Thanks Doog, Ike was a nice guy,I think I went to school with him.
#2457468 - 12/08/11 08:31 PM Re: How not to highside? [Re: mjoekingz28]
Mackelroy Offline
Loc: Florida /Texas
__________________________________________________
If you chop the throttle, once the rear has kicked out, then you can have issue, easing off throttle some may catch the tire in the early stages. so can clutch use. Pressing on the outside peg can also limit a break out .
It also helps to be able to feel traction levels and adjust in the early moments, some people are numb to traction feel
But once the tire catches and if your in a crossed up position, you need to be on the gas hard to pull out of it, cause if you dont highside , its going to definitely want to tank slap at the very least.
#2457512 - 12/08/11 09:20 PM Re: How not to highside? [Re: Mackelroy]
Thanks all but this is what I want to hear. Once you lose traction from the rear, how do you regain it safely? Although I cannot picture how to do what you wrote, it seems to me that it makes sense. I guess understanding what to do while benchracing will help when you get a go at the track.
#2457521 - 12/08/11 09:30 PM Re: How not to highside? [Re: mjoekingz28]
CBR.worm Offline
Loc: Jupiter, Fl
If it is wet and the rear (or front) starts to slide and you hit a dry patch, you won't regain it gracefully unless it is a really small dry patch.
If the track is dry and the back starts to slide under power, staying on the gas will allow the grip to be regained slowly and smoothly under ideal conditions - but you have to be careful not to let the tire spin up more, causing you to lowside (which is preferable). If you chop the throttle in that scenario it will grab hard and throw you. Just like if you hit a dry spot when sliding in the wet.
The best solution on a wet track with dry spots is to ride less aggressively - preferably on rain tires.
'06 Infiniti G35 Sedan 6MT - 160k
Page 1 of 2 1 2 >
