Originally Posted By: Grebbler
Just wrapping my brain around this.
okay, 360 degrees of tire sidewall. Say the machine feels more road force (sidewall stiffness?) at 22 and 65 degrees. Does the machine instruct the operator to add some weight in those areas to counter the stiffness?
I assume that there would be a 'sweet spot' the machine is calibrated for since the sidewall stiffness would be constant at any speed while a rotating weight would increase the downward force as the rotation speed increased.
Please correct my misconceptions.
Ed
First, the Hunter GSP9700 - as do all uniformity machines - measures the difference in force variation (FV) around the tire. Force variation is a combination of sidewall stiffness variation and run out.
It takes a couple, 3 revolutions to get a good reading. Remember, on the Hunter GSP9700, the tire is mounted on a wheel - so the machine is measuring the variation of the assembly - the combination of the tire and wheel.
Tire manufacturers have production uniformity machines - high volume, feed by conveyors - and the important point - the rims are precision ground, split in the middle and part of the machine set up. It takes about 30 seconds to measure a tire on one of those machnines. BTW, the last time I checked - many years ago - they cost about $600K each. I'm sure they are bumping a million by now! One of our plants has about 30 of them - a serious investment! The Hunter GSP9700 is about $10K!
So keeping in mind that both machines get a FV curve, then they do a mathematical curve fit of a single sine wave to the data. This is called the 1st Harmonic. The high point of that sine wave can then be matched to the low point of the wheel runout to minimize the overall values for the assembly - which mean you need to know where the low point of the rim is.
In the case of the production machines, the size of the sine wave is compared to a specification. If the tire is below the spec, the tire MAY be marked for location (and sometimes value), then sent down the line.
A tire that does NOT meet specifcation is pushed onto a different conveyor. There are things that can be done to improve the uniformity value of a tire. The common method is called "Force Correction" - which is a fancy way of saying they grind off a few thousands of an inch of tread rubber at the high point, which lowers the overall variation. This is frequently done to OE tires to meet the OEM's specs, which are pretty tight.
The Hunter GSP9700 will tell you where the high point of the assembly is - and the machine has some built in tolerances that it compares against. The machine will alert the operator when that tolerance is exceeded. If that happens, the operator can take one of 2 steps.
1) The operator can dismount the tire and measure the bare wheel. This is the best way as this is measuring the surface that the tire sits on. However, it is labor intensive.
2) He can get an estimate of where the low point of the wheel is, by measuring the runout of some part of the wheel. This is always problematic as the tire is on the surface that needs to be measured. Any other location may not be a true picture of what is going on.
The Hunter GSP9700 takes the wheel runout data and subtracts it - point by point - from the assembly data, calculates the best fit 1st Harmonic to the both the rim and the tire, then tells the operator where the high point of the tire is and where the low point of th rim is. - which can then be matched up.
If the tire is not reoriented on the wheel, then the Hunter GSP9700 is no better than a normal balancer - except you know what the uniformity value is. Where the machines is valuable is that it can measure and minimize the run out.
OK, time for a lesson on the vehicle end of things:
Each vehicle has a certain sensitivity to wheel end vibrations. Some vehicles are very sensitive and some are very insensitive. You don't need to minimize EVERY tire and wheel assembly. You just have to avoid putting assemblies on that are above the sensitivity limt for that particular vehicle. If you know the vehicle's sensitivity, then using the Hunter GSP9700 can prevent a lot of vibration problems.
I know that was a little long, but I hope it was helpful.
I could go on about high speed vs low speed force variation - about putting weights on the rim to counteract the FV - but that is another long discussion!
