You need to locate the bleeder bolt on the clutch cylinder, follow the line off the reservoir down to the transmission, on the piston that moves the throwout bearing, you will find a little bolt on the end with a little black cover, take this off, this is your "bleeder bolt."
The procedure will take two people, someone to push the clutch pedal down/ let it out, and one to open/close the bolt
You will need to open the bolt with approx. an 8mm wrench, then tell the person in the car to push down the clutch slowly, fluid should shoot out, when he gets the pedal to the ground, close the bolt, then tell him "up." make sure to be watching the reservoir's fluid level and make sure not to let it run dry and suck up air. Repeat until you flush through about an 8oz can of dot 3 or 4 or hydraulic clutch fluid, then shut the bleeder tight, then put the cap back on the end of the bleeder and take it out for a spin to see if it fixed the issue.
*** Sorry if I explained it like you were dumb, but it is easier to go further in depth than necessary than to leave the question half answered, hope this helps!!
