So the battery on our Fit looks like it's dying. It's cranking hard on starts after it's been sitting for a while, like 20 minutes to a few days. It's done this for a while, and gotten progressively worse. With the weather finally turning colder, I'm now looking at batteries for it. Looking at the Fit boards, it's common for the OEM battery to die after 2-3 years. So ours is due. And surprise, surprise, there's no locally available replacement battery! The nearest Honda dealer is about 80 miles away, and they might not have one in stock either.
The stocker has the following dimensions:
~7 1/4"L
4 7/8"W
9"H
It looks like a Miata battery might fit. The dimensions on the Miata battery are: 8 1/4"L, 5 3/16"W, 7 3/16"H. CCA and reserve capacity are similar enough where it doesn't matter. More importantly, it is available locally.
Try it out or hold off?
~7 1/4"L
4 7/8"W
9"H
