Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
Fllow the DOT's
by WyrTwister
04/29/16 07:23 PM
Auto Rx?
by coopns
04/29/16 06:54 PM
Rotella for 6.0L Gasser
by Joefuskie
04/29/16 04:40 PM
Pennzoil Platinum Euro 5W-40
by 1JZ_E46
04/29/16 04:21 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
46 registered (Blkstanger, 901Memphis, 2015_PSD, Alex38, Bryanccfshr, 9 invisible), 891 Guests and 95 Spiders online.
57748 Members
66 Forums
248231 Topics
Page 1 of 2 1 2 >
#2452218 - 12/03/11 07:06 PM Fixing Bad Catalytic Converters With P0420
55Test Offline
Loc: New Brunswick
The total sum of everything I have learned from this website: ...Oil in engine, good!
#2452231 - 12/03/11 07:28 PM Re: Fixing Bad Catalytic Converters With P0420 [Re: 55Test]
JHZR2 Offline
Loc: New Jersey
Hmmmmm. Well, if it is truly a poorly functioning converter, a few things could work.
One is to remove soot on other surface is exposed, offering up new active material that is not sulfided.
Another would be to reduce the catalyst to bare metal, then re-oxidized.
Third would be to cook the converter to remove the sulfides, though per-reduction would be beneficial.
If a poison is limiting activity due to alloying with the PM, I suppose the only way to go us to remove the material that has alloyed and/or coated to the pm.
Generally the metals are just recovered though, generally through a nasty chloride process.
#2452314 - 12/03/11 09:18 PM Re: Fixing Bad Catalytic Converters With P0420 [Re: 55Test]
L_Sludger Offline
Loc: NORTHCOM AOR
A good fix for P0420 is a couple of spark plug anti-foulers screwed into the post-cat O2 sensor bung, with the O2 sensor screwed in at the end.
#2452523 - 12/04/11 06:38 AM Re: Fixing Bad Catalytic Converters With P0420 [Re: 55Test]
LeakySeals Offline
Loc: MA
Scotty's excellent. He's proven its possible. However his soapy water methods are prior to recent chemist studies that found a Citric Acid bath is the way to go over soaps that contain some oils and other products. If you google around you will find people that have done it with success.
I plan to do this on the front manifold cat when I have time. From what I read you buy Citric Acid Powder, mix it with warm water, let cat soak immersed 6-8 hours, pressure rinse (not too much). My attempt will be without taking the manifold cat off the head, disconnect the manifold cat at the exhaust donut, remove upstream o2, using double garbage bags immerse cat in the Citric Acid/warm water mix, duct tape the bag to the cat, go to bed. Come out in the morning, try rinsing somehow, let it drip dry, put it back together. Maybe let the car steam dry the media, might clean out farther down.
Edited by LeakySeals (12/04/11 06:49 AM)
02 Camry XLE 2AZ-FE 345k M1 HM 5w30
06 Escalade 132k. M1 0w30
#2452793 - 12/04/11 12:35 PM Re: Fixing Bad Catalytic Converters With P0420 [Re: 55Test]
Vikas Offline
Loc: NorthEast
Scotty also recommends paint thinner (or was it Acetone) in the gas tank to clean the converter.
#2453365 - 12/04/11 10:27 PM Re: Fixing Bad Catalytic Converters With P0420 [Re: 55Test]
brianl703 Offline
Loc: Manassas, VA
How about putting it in a self-cleaning oven?
#2453424 - 12/05/11 12:04 AM Re: Fixing Bad Catalytic Converters With P0420 [Re: brianl703]
91344George Offline
Loc: CA
You need something to "wash away" the contaminants really, in a sense when you drive you are already baking the metals...
It has to be something that has a chemical reaction more than just heat.
#2453599 - 12/05/11 08:56 AM Re: Fixing Bad Catalytic Converters With P0420 [Re: 55Test]
brianl703 Offline
Loc: Manassas, VA
Lot more oxygen in a self cleaning oven so the contaminants will burn up much better.
#2453685 - 12/05/11 10:48 AM Re: Fixing Bad Catalytic Converters With P0420 [Re: brianl703]
Vikas Offline
Loc: NorthEast
Is your marriage worth more than the cat? If so, don't do it :-)
#2453710 - 12/05/11 11:29 AM Re: Fixing Bad Catalytic Converters With P0420 [Re: Vikas]
HerrStig Offline
Loc: Boston, MA
New cats for NON- "CARB" (Federal) cars are not that expensive. Try Rockauto. There's still a half dozen states where you don't NEED an emissions test, Florida among them. For the rest it's "monkey see, monkey do" like Maine.
#2453716 - 12/05/11 11:34 AM Re: Fixing Bad Catalytic Converters With P0420 [Re: 55Test]
HerrStig Offline
Loc: Boston, MA
BTW I have a Gen 4 Camry in the "fleet" with a blown out front - in the manifold - converter (by observation) but a good quality rear converter. The sensor which "rats you out to the ECU" and turns on the Check Engine light is behind the rear converter. No OBDII check engine light problems, and the rear conveter is not that expensive, even Amazon has them. It's passed two PIMA inspections in my state, where they hook a computer right to the OBD port. The front O2 or A/F sensor usually right on the manifold or down pipe is for the mixture setting feedback loop, , the rear one is the smog cop.
Edited by HerrStig (12/05/11 11:38 AM)
#2453982 - 12/05/11 04:16 PM Re: Fixing Bad Catalytic Converters With P0420 [Re: HerrStig]
LeakySeals Offline
Loc: MA
They also have the ECU programmed to reject aftermarket manifold cats wink
#2454092 - 12/05/11 06:30 PM Re: Fixing Bad Catalytic Converters With P0420 [Re: L_Sludger]
MarkM66 Offline
Loc: stl
Exactly!
#2455249 - 12/06/11 08:05 PM Re: Fixing Bad Catalytic Converters With P0420 [Re: HerrStig]
artificialist Offline
Loc: Florida
That is because on most of those cars the front one is designed to work best while the engine is cold, afterwards, the one downstream does the majority of the work when the engine is hot. This is why sometimes the upper can fail, yet still pass a smog test.
However, on some cars, the one closer to the cylinder head is for NOX only, and the one downstream is for HC+CO only, but the oxygen sensor positioning is the same. This is more common on Fords. Secondary O2 sensors detect the conversion of HC+CO-> CO2 H20 but not NOX, typically. You might end up with no code P0420, but if the car was hooked up to an exhaust gas tester, you could fail the NOX test.
2010 Lancer Ralliart Sportback
#2455406 - 12/06/11 11:24 PM Re: Fixing Bad Catalytic Converters With P0420 [Re: 55Test]
KeithS_NW_Ohio Offline
Loc: Bowling Green, OH
Page 1 of 2 1 2 >
