Originally Posted By: The Critic
I can understand why 5W30 may give you inferior start-up protection and higher oil temps, but I would like to hear the explanation for seal wear and film strength.
The film strength argument is detailed
here more thoroughly and eloquently than I could ever do. The chart on Fig 9 and the relevant comments give a good explanation as the the theorized mechanisms, along with some real-world test results.
As far as seal wear, the mechanism is simple: friction and pressure create wear. This paper
here goes into the details, as do a couple of others. That one isn't in the public domain, but if you're really interested you can find the relevant passages in some other published papers; but basically, any time the fluid friction layer is more than necessary, pressure is created--along with wear. The ideal viscosity for seals is "as thin as possible, as long as it's not leaking".
Originally Posted By: JHZR2
Im not sure I understand why in the mild climate of Boise (its all dependent upon minimum startup temps), the 5w-30 would give inferior start-up protection. A 0w oil isnt necessarily flowing better at temperatures far from -35.
Who said it would? Comparing a 5W30 to a 0W30 in a mild climate? Sure, there's not much difference. Comparing a 0W30 or 5W30 to a 5W20 is a different matter though--the 30W oils are going to be quite a bit thicker at start-up.
Heck, at 40C, straight weights are generally less viscous than their multigrade siblings.
umm...huh? You may want to give that one a re-think.
