WRX or GTI?
by GumbyJarvis
58 minutes 8 seconds ago
Single cylinder versus twin
by mjoekingz28
Today at 01:12 AM
Mobil Super Syn vs ...others
by Yup
Today at 12:45 AM
2016 WRX
by Silver02ex
Yesterday at 11:58 PM
Class Action Lawsuit Against Oil Filter Company?
by crazyoildude
Yesterday at 11:42 PM
PL10241 Cut Open
by Vegoose
Yesterday at 11:15 PM
Seems like common sense to me......
by Doog
Yesterday at 11:14 PM
Thinking of buying an old diesel Benz
by Diego3336
Yesterday at 10:46 PM
Mobil 1 5W30 5279 Miles 06 Toyota Tacoma V6 401k
by qnyla
Yesterday at 09:43 PM
2007 corolla oil pan steel or aluminum?
by Rolla07
Yesterday at 09:07 PM
Taiwan DMV "Mechanical Knowledgee" Test Question
by Ducked
Yesterday at 08:56 PM
Paint correction
by mjoekingz28
Yesterday at 08:55 PM
engus, Rob_Pol, Nick24w, SkipKaye, MikeHancho
56899 Registered Users
29 registered (crinkles, Ducked, dgunay, DSparks, c502cid, deoxy4, 3 invisible), 423 Guests and 187 Spiders online.
56899 Members
66 Forums
244581 Topics
Page 2 of 4 < 1 2 3 4 >
#2445760 - 11/26/11 11:50 PM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
I drive a 98 Saturn sl2 now
2004 Honda civic vp -m1 5w30
1998 Saturn sl2 -mobil super 5000 5w30
#2445775 - 11/27/11 12:26 AM Re: how long can a water pump last? [Re: Dakota1820]
Nick R Offline
Loc: Albany, NY
Like I said there was nothing wrong with the water pump, it wasn't leaking. As I said since the engine was already apart I figured I might as well change it.
2013 Ford Focus SE 2.0L/67,000miles/Motorcraft Blend 5W-20/FL-910S
#2445781 - 11/27/11 12:48 AM Re: how long can a water pump last? [Re: Dakota1820]
wirelessF Offline
Loc: Oahu, Hawaii
I had almost 100k miles on the water pump on my toyota truck. Changed the timing belt and the works and the mechanic showed me the old water pump where coolant was coming out of the weep hole.
#2445784 - 11/27/11 12:59 AM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
Hmm mine isn't leaking but I dont like being in sudden bad situations. And with an aluminum motor it doesnt take much of a bad situation to kill it for good. That's why I worry .
#2445797 - 11/27/11 02:06 AM Re: how long can a water pump last? [Re: Dakota1820]
expat Offline
Loc: Canada
NEVER had to change a water pump*, I have a Triumph that's 37 years old, and once had a Toyota Truck that had close to 500k.
* Had a VW Golf and changed the WP at the time the timing belt was changed, But not sure if that counts?
#2445811 - 11/27/11 04:21 AM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
500 k on the oe pump? Holy [censored] your one lucky guy I guess that's a lot of miles
#2445820 - 11/27/11 04:57 AM Re: how long can a water pump last? [Re: Dakota1820]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Originally Posted By: chevyboy14
Well if it weeps it is bad correct?
Slight weeping is normal on some vehicles. There wasn't a lot of weeping with Chev small blocks, though, for instance. Generally, you're not going to see a catastrophic failure. You'll have leakage and bearing noise, first.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#2445876 - 11/27/11 07:47 AM Re: how long can a water pump last? [Re: Dakota1820]
eljefino Offline
Loc: ME
Doing a friend's saturn 1.9 water pump today. Been leaking progressively worse for months now.
They don't just fail leaking, the impellers can bust loose or slowly disappear and become ineffective.
#2445893 - 11/27/11 08:09 AM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
How many miles does his have?
#2445932 - 11/27/11 09:05 AM Re: how long can a water pump last? [Re: Dakota1820]
exranger06 Offline
Loc: Guilford, CT
The original pump on my Explorer lasted about 159k miles. The replacement one didn't last 7k miles.
2006 Ford Ranger Sport
1992 Honda Accord EX
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek (wife's)
#2445981 - 11/27/11 10:07 AM Re: how long can a water pump last? [Re: Dakota1820]
SteveSRT8 Offline
Loc: Sunny Florida
Our fleet trucks have gone all the way out to 300k miles, but 200+ is more typical for us.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2446007 - 11/27/11 10:35 AM Re: how long can a water pump last? [Re: Dakota1820]
Jim Spahr Offline
Loc: Lexington, SC
1996 Chevy Lumina with 75K I just replaced the OEM w/p and it was easy, especially for a FWD car. It was sitting on top front of the V6 and you replace the impeller , not the housing, so it is very straight forward. And a Brand New pump from AZ was only 20.00. Now the Thermostat is a whole different story. It is the FWD nightmare you would expect.
Chevy Impala SS 1994 LT1 5.7L V8
Chevy Blazer LS 4WD 2003 4.3L V6
Chevy Lumina 4 door 1996 3.1L V6
#2446610 - 11/27/11 07:39 PM Re: how long can a water pump last? [Re: Dakota1820]
Rhymingmechanic Offline
Loc: VA
On a '94 Saturn SL1, I changed what I'm fairly sure was the original pump at 173,000. The lifetime warranty replacement from Advance lasted 22,000. My '01 Silverado started leaking at around 80,000. My other pumps have lasted somewhere between those two figures. Not that they can't fail immediately, but mine have always started leaking progressively more from the weep hole.
#2446677 - 11/27/11 08:29 PM Re: how long can a water pump last? [Re: Dakota1820]
artificialist Offline
Loc: Florida
Japanese cars usually get great life out of the pump, but only if you use the non-silicate coolant. My parents learned the hard way that just because Honda and Mitsu coolant is green in color does not mean it is the same green stuff sold in Advance Auto.
Many American cars get good life from their pumps too, they weren't the ones who dyed coolant in such ways. Green was green, orange was orange, up until recently.
There is another factor in water pump life. This destroys many of the more recent ones. Some pumps have a plastic impeller that will have a blade fail. The engine will overheat, but coolant will not leak out of the water pump, causing confusion. VW cars are the worst for this.
2010 Lancer Ralliart Sportback
#2446682 - 11/27/11 08:36 PM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
Mine has 192k I figured it has been replaced before but not sure looks old
