This is my first UOA, but my third interval with M1 0W-40. During this interval, I had the valve cover off to retorque the head bolts as a precaution (most were improperly torqued from the factory) and I probably got some dust in there, as it was a little windy that day (and I was outside). Silicon is still pretty low, though. I know that high lead and iron numbers are normal in a Saab, but I'd like to see them a bit lower. I switched to M1 5W-40 for the next interval. This seemed to help in Eiron's Saab (same engine) so we'll see if it holds up for me too.
[ June 01, 2005, 01:49 PM: Message edited by: MO ]
code:
1999 Saab 9³ base model
B204 2.0L turbo engine
75,300 mi on car and engine
5000 mi on oil
no makeup oil added (about 1/4 L lost)
Notes: using K&N air filter
using Saab oil filter
using magnetic oil drain plug
oil was in use during cold Boston winter
driving involves lots of short trips (5-6 miles)
Notes from Blackstone:
No problems showed up in the initial sample from your 99 Saab. Wear generally read a
little higher than average, though nothing was high enough to draw concern at this point. The
universal averages show normal wear after about 5,100 miles on the oil. Silicon was low at 7 ppm, so
we don't think any significant dust contamination was present from the work that was done. The low
flashpoint shows a minor amount of fuel in the oil. It was well below our problem level of 2.0%. No
anti-freeze was found. At 75,300 miles, this engine appears to be doing well.
Element Measured Univ. Avg.
Al 4 3
Cr 3 1
Fe 32 21
Cu 4 4
Pb 16 8
Sn 3 1
Mo 77 52
Ni 1 0
Mn 1 6
Ag 0 0
Ti 0 0
K 0 1
B 115 63
Si 7 8
Na 5 8
Ca 2699 2402
Mg 18 134
P 818 812
Zn 994 941
Ba 0 0
Test Measured Should be
SUS Viscosity 210F 66.6 65-76
Flashpoint, F 375 >375
Fuel %
Antifreeze % 0.0 0
Water % trace
Insolubles % 0.2
