I'm sure these have been posted before but...
by Yup
05/30/16 01:24 PM
Weedeater nylon cutter cartridge doesn't feed out
by 69GTX
05/30/16 01:23 PM
Larger Oil Filter for 2006 Highlander 2.4 Four Cyl
by Samzone
05/30/16 01:01 PM
I bought a Stihl weed trimmer, but...
by skyactiv
05/30/16 01:01 PM
2010 Tacoma oil selection help
by bchannell
05/30/16 12:52 PM
Will this "Universal" coolant work on my Car?
by Miller88
05/30/16 11:37 AM
Repelling heat
by mjoekingz28
05/30/16 11:27 AM
Wrong Dipstick? Honda Accord 2.4 Reading Low
by ThirdeYe
05/30/16 09:09 AM
radiator hose install, 08 Matrix.
by JustinH
05/30/16 08:56 AM
Bendix CT-3 Brake Pads
by RevelationLion
05/30/16 08:38 AM
Ever Have A Funniest Home Video Moment?
by coopns
05/30/16 08:20 AM
Parties
by AirgunSavant
05/30/16 08:02 AM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
79 registered (69GTX, Astro14, andyd, Astro_Guy, AirgunSavant, 5 invisible), 1935 Guests and 337 Spiders online.
58023 Members
66 Forums
249596 Topics
Page 1 of 2 1 2 >
#2429471 - 11/09/11 12:23 AM SP III ATF equivalent
berniedd Offline
Loc: A Warm place to live in
My Kia manual says to use SP III ATF for my Sportage. If I were to go to Walmart, what equivalent rating should I look for on the label ?
#2429503 - 11/09/11 02:31 AM Re: SP III ATF equivalent [Re: berniedd]
Falcon_LS Offline
Loc: Kuwait
Mopar ATF+4.
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#2429626 - 11/09/11 08:10 AM Re: SP III ATF equivalent [Re: berniedd]
JTK Online   content
Loc: Buffalo, NY
Originally Posted By: berniedd
... what equivalent rating should I look for on the label ?
Valvoline Maxlife ATF is readily available at Wally and specs SPIII use right on the bottle.
There's lots of posts on this in this forum
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2429830 - 11/09/11 11:35 AM Re: SP III ATF equivalent [Re: JTK]
ChrisD46 Offline
Loc: GA.
Many suggest staying with Kia / Hyundai SPIII ATF and not chance it .
#2429851 - 11/09/11 11:54 AM Re: SP III ATF equivalent [Re: berniedd]
EricF Offline
Loc: SF Bay Area
ATF +3 or +4 is perfect
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#2429972 - 11/09/11 01:57 PM Re: SP III ATF equivalent [Re: ChrisD46]
Boss302fan Offline
Loc: Oconomowoc Wi
Maxlife ATF works great in this application if not better...
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#2430561 - 11/10/11 07:28 AM Re: SP III ATF equivalent [Re: berniedd]
The_Eric Offline
Loc: Iowa
Many NAPA stores can get or stock Eneos Type SP, which is intended directly replace SP III.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#2430812 - 11/10/11 12:49 PM Re: SP III ATF equivalent [Re: berniedd]
Rand Offline
Loc: NE,Ohio
is there a warranty ?
if so I'd recommend factory spIII
if there is any issue with your transmission they send out a fluid sample to be tested for markers that are in the factory fluid.
It does matter if the issue was caused by fluid or not they will most likely deny you without the factory SPIII fluid.
If out of warranty there are alternatives that are fine.
Edited by Rand (11/10/11 12:50 PM)
2015 Forester I-Premium 6MT
#2432462 - 11/12/11 06:36 AM Re: SP III ATF equivalent [Re: Rand]
hemitom Offline
Loc: canada
I'm using maxlife in my kia , my observations, fluid does not darken like the sp3 does this mean anything? The shifts are much smoother on both the up shift and down shift.. I think most kia transmission problems were on the prior 2005 model and below, i believe its was a two fold problem one the transmission were of poor quality and design and the sp2 and 3 fluids were and are a so-so fluid at best.
Edited by hemitom (11/12/11 06:42 AM)
2006 kia spectra
2006 chrysler 300 (gone to mopar heaven)
2009 hyundai santa fe
2004 mustang GT.
#2432722 - 11/12/11 02:16 PM Re: SP III ATF equivalent [Re: berniedd]
bowlofturtle Offline
Loc: Chicago
i've been on the ropes about maxlife mainly because i never tried it. I have a lancer that slips every now and then under medium acceleration. Its 80k now and had D&F @35k and 62k. I'm thinking maxlife will either make it better or worst and doing SP3 again will keep it the same. I figure maxlife since i can get it cheaper + lubeguard is worth a shot in my book.
When i'm at 90k hopefully AAP's coupons are still good for the 20$ off $50 of fluid.
- 2005 Infiniti G35x 106k
- 1998 Nissan Maxima GLE 145k
- 2003 Mitsubishi Lancer OZ-Rally 104k
- 2009 Toyota Camry XLE V6 86k
- 2003 Suzuki SV650N 8.5k
#2432783 - 11/12/11 03:49 PM Re: SP III ATF equivalent [Re: berniedd]
RPMster Offline
Loc: Southern California
I'm using Maxlife in place of SP-III and it works great. Smoother overall operation, and the Maxlife fluid appears to be in better shape after 20K miles of service. Feels better rubbing between the fingers too.
As far as Lubegard goes: I would only use red bottle, and only in severe duty applications such as heavy towing where a cheaper conventional fluid is being used. IMO: a well-engineered synthetic ATF does not need any additives.
#2443306 - 11/23/11 09:07 PM Re: SP III ATF equivalent [Re: berniedd]
keith Offline
Loc: Connecticut, USA
If there is a factory warranty on the tranny, go to the dealer and buy the SP-III?
My wifes 2007 Elantra just passed 100K miles and I flushed 8 qt. of ST ATF+4 in there, purging old SP-III. Very satisfied with the performance of ATF+4 in the Elantra. It shifts like it should, no excess slippage or roughness.
#2443320 - 11/23/11 09:23 PM Re: SP III ATF equivalent [Re: keith]
wymi516 Offline
Loc: Illinois
What led you to choose the ATF+4?
2013 Mazda3 iTouring 2.0L DI M1 0-20 OE Filter
2013 Chevy Impala 3.6L DI M1 0-30 OE Filter
2014 Chrysler 200S 3.6L PFI M1 0-20 OE Filter
#2443346 - 11/23/11 09:50 PM Re: SP III ATF equivalent [Re: berniedd]
Knox Offline
Loc: Kansas, USA
Napa carries eneos SP3 fluid.
Eneos Data
2009 Subaru Legacy (Special Edition)
Delo XLE 10w-30 and Napa Gold 7712
#2443478 - 11/24/11 04:04 AM Re: SP III ATF equivalent [Re: berniedd]
Ross Offline
Loc: Bismarck, ND
I have two mitsubishi made chrysler cars that call for spIII. Per a chrysler TSB, I am using atf+4 in both trans and steering units without issue for 4+years.
NUMBER: 21-003-02
GROUP: Transmission
DATE: Jul. 29, 2002
SUBJECT:
ATF+4 Usage
OVERVIEW:
This bulletin provides information about ATF+4 usage in ST22 models.
MODELS:
2001 - 2003 (ST) Sebring/Stratus Coupe
DISCUSSION:
ATF+4 (type 9602) is approved for use in Sebring/Stratus Coupe power steering and automatic transaxles. The fluid is fully compatible in power steering systems and no additional maintenance information is required. When using ATF+4 in automatic transaxles, the following information is required for proper service and maintenance.
SCHEDULED MAINTENANCE
When using ATF+4 as a complete fill in Sebring/Stratus Coupe models, the maintenance for schedule A is changed to a 60,000 mile fluid replacement interval. Schedule B remains the same as listed in the owners manual. The owner should be notified about this schedule change when ATF+4 is used as a complete fill.
NOTE: USING ATF+4 FOR TOP OFF WILL NOT CHANGE THE ORIGINAL CHARACTERISTICS OF THE FACTORY FILL OR ORIGINAL MAINTENANCE SCHEDULE.
GENERAL SERVICE FILL
ATF+4 is fully compatible for top off or for any transaxle service procedures that would require fluid fill or fluid replacement. Special considerations are required if a new torque converter is installed.
TORQUE CONVERTER REPLACEMENT
If a new torque converter is installed, ATF+4 can be used however, green torque converter shudder MAY be experienced. If green torque converter shudder is experienced, it will be eliminated over time as the torque converter clutches wear or burnish in. If shudder occurs, the vehicle can be driven (in torque converter partial lockup) until the condition is eliminated. If customer concerns arise due to green torque converter shudder use the following procedure.
NOTE: TO ELIMINATE ANY CONCERNS OF GREEN TORQUE CONVERTER SHUDDER, THE TRANSAXLE CAN BE FILLED WITH DIAMOND SPIII FLUID PN 05073942AA DURING THE INITIAL FILL.
land of fieros
88 fiero gt t-tops 3,000 original miles
09 saturn outlook
11 hyundai accent se
03&04 mitsubishi made chrysler sebrings
06 buick lucerne
Page 1 of 2 1 2 >
