When I was at the shop today for a transmission service, the technician told me that my parking brake (foot-operated) was out of adjustment. Sure enough, I checked the factory service manual when I got home and found the spec to be 8-11 notches at 67.5lbf. I am not sure how to accurately reproduce that amount of pressure, since according to my dad, I tend to exert a gorilla-like force on everything. My own test of the parking brake concluded that it was taking between 15-17 notches, then again, I stomp the pedal hard.
The adjustment nut was quite loose and only after 5-6 full turns did I begin to feel some resistance. I think I turned the nut about 7 full turns in the end.
After the adjustment, if I do a gentle push to engage the parking brake, it results in 5 notches. If I give it a bit more pressure and/or stomp on it like I normally do, it takes 7 notches. The parking brake pedal also feels reasonably firm as well, unlike before.
The car rolls fine in neutral. If I put the car in Drive and allow it to roll and try to use the parking brake to stop the car, it takes 2 clicks before the car will come to a stop. Similarly, if the car is rolling backwards on a flat surface in neutral, it takes 1 click to stop the car. With those results, I am assuming that this means the parking brake is properly adjusted and is not dragging excessively?
Let me know what you guys think.
Thanks.
Thanks.
