I have a new Echo Leaf Blower that was purchased last year and not run at all since new. Gasoline was put in it last November and just stored. We don't know if a "stabilizer" was put in the gasoline or not. We normally do but things happen....
Anyways, here is the problem. It cranks fine but will only run at full throttle when we turn it upside down. It will run at the highest rpm upside down. Also, under full throttle it will bog down.
A local repair guy said we need to buy a new carb????????
What do you think?
What do you think?
