There were several postings noting that the Falex gives good correlation with the Sequence IIIE engine dynamometer test.
" The Falex Pin and V-block does have a nice correlation to high
temperature camshaft wear as in the Sequence IIIE engine test".
When laboratory bench tests are found that correlate with either single or multicylinder engine tests, there usually is a paper published in SAE or STLE that gives the evidence of such correlations. I do not recall seeing any such paper and would like to know if any thing has been formally published. There is an active group in the ASTM D2 Technical Committee B on Automotive Lubricants that is trying to collect data on such tests and would be most interested in such data. The need for laboratory bench tests that can eventually replace the highly expensive engine sequence tests has been a long sought goal of both the oil producers and engine manufacturers.
