Amsoil Interceptor Oil??
Pennsylbammyvania
Does Amsoil's Interceptor Oil qualify as a TCW3 oil even though it does not state that spec ANYWHERE on the bottle??
Does the JASO spec which IS on the bottle supercede/replace the TCW3 spec?
(So that it can be used as an UCL fuel additive in 4 cycle, catted engines.)
Pablo, anyone?
Don't think it supersedes TCW3.
May I ask why use Interceptor? When both HP Injector and Saber Outboard are both TCW3 oils?
Just Askin, Jim
Originally Posted By: Pablo
No.
What is this for?
Saber is probably what you want for TCW3.
You can use pretty much any of the oils for a UCL in a 4T engine.
That's EXACTLY what it is for Pablo (UCL in a 4-stroke automotive engine).
So am I (and my catcons/O2 sensors, etc.) just as safe using the Interceptor (even though it is not TCW3 rated) as I am using the Saber Outboard, or HP Injector products??
What mix ratio?
What mix ratio?
Maybe 3 ounces to 16+ gallons of 93 octane Shell V-Power.
That's like 680:1 and it makes no difference which oil.
What ratio do you suggest with that oil??
Interceptor you could use 400 or 500 to 1 in a 4T engine. It burns really clean (the 2T guys say too clean)
