Originally Posted By: addyguy
I've read here, somewhere, that Mazda allows the use of 40-weight in the turbo engines.
If you want to use Amsoil, either XL 10W-40, or Euro 5W-30 or 5W-40 would be good choices.
im also seeing that 40w seems to be good in these motors..? as a recommendation from am amsoil rep i will probably do the OE series. im sure the euro is very good stuff but [censored] its not cheap. i normally change around 4000-5000 miles. so i really dont need something that can go "20,000" miles before a change. i guess i will stick with oem filters. they are cheap.
