Originally Posted By: landtoy80
I think I have oil leaking past the valve guide seals. Two of the 6 spark plugs had oil on the threads.
My thinking is that the oil is soaking into the carbon/build up on the piston. I have noticed that after the B-12 treatment I have not see as much (hardly any) start up smoke. Maybe the build up is going away.
What color smoke would there be from gas leaking and soaking into the buildup as it is burned off if that was my problem?
You need your Valve Seals replaced, there is no fuel or oil additive that is gonna help you out.
