I'm putting this Perkins engine back together and the manual says to use motor oil on all the bearings, etc. Would there be any disadvantage to using assembly lube? It seems like assembly lube would stay in place better till the engine builds oil pressure and it gets running again. I already have a tube of it and wouldn't mind using it up.
