Originally Posted By: mikered30
I have a whine during heavy acceleration in my 06 that I can't get rid of but besides that it is fine. This occurred with the t iv fluid and redline d4 fluid.
These transmissions are bulletproof, but many of them do have this annoying whine issue under acceleration, especially when the fluid gets to normal operating temperature. I've done a lot of research on this and both 9 and 10 generations have this problem, so you really have to watch for it. There is no solution except to replace the transmission, but even a replacement can develop this whine in the future. The whine does not cause a failure or any other problems, it is just there and is very annoying. Some toyotas are louder than others, in some you can barely hear it, but they do have this problem. Dealerships consider this "normal" and will do nothing about this under warranty. My new 2010 corolla had this whine from day 1 and I could not get the dealership to do anything about it. I had to call Toyota USA and raise a complaint, this finally got the dealer to replace the tranny at 2000 miles, but even the new replacement unit has the same problem, except it is a lot less noticable. Unless it is over 70 F outside, it does not do it, but in hot weather under heavy acceleration it does whine, so beware of this issue.
