Just an interesting question
by southernjeeper
05/26/16 01:52 AM
Value power Walmart battery acid flying out
by bbhero
05/26/16 12:44 AM
Leased 2013 Ford Suv With19,882 Miles Original Oil
by crazyoildude
05/25/16 10:35 PM
Steak-House Burgers
by sleddriver
05/25/16 09:53 PM
Got into an accident.
by bdcardinal
05/25/16 09:42 PM
Its coming here more and more
by CourierDriver
05/25/16 08:40 PM
Interpreting oil pressure vs engine RPM
by Emperors6
05/25/16 08:39 PM
$4 Fram Ultra - Blain's F&F
by Poohbah
05/25/16 08:21 PM
Toolbox - Pliers
by greasegunn
05/25/16 08:09 PM
ProSelect Oil Filter????
by qwerty1234
05/25/16 08:05 PM
Completing your 80% lower with a CNC Machine
by Merkava_4
05/25/16 07:33 PM
Motor oil Sale
by GuinnessGuy
05/25/16 07:26 PM
jerryg, 1971tr350, Mak712, Lex4TDI4Life, cdub76
57988 Registered Users
27 registered (asand1, Burt, Bandito440, Astro14, 4 invisible), 583 Guests and 283 Spiders online.
57988 Members
66 Forums
249411 Topics
#2426222 - 11/05/11 07:12 PM Can I pull 12V from a 24V system?
antonmnster Offline
Loc: Minneapolis
Another long winter is about to start, and I'm going to be spending serious hours in my work's Pisten Bully groomer out on the trails.
As most heavy equipment does, it uses a 24V system, running two 12V batteries in series. I have some 12V accessories that I'd like to use to keep me company, maybe even a new head unit that has better performance than the Euro-trucker Blaupunkt that's in there now.
Would it be possible to pull 12V from in between the two batteries? Would there be 12V on the series jumper with a chassis ground?
I'd go check with a volt meter, but I'm not at work...
#2426229 - 11/05/11 07:20 PM Re: Can I pull 12V from a 24V system? [Re: antonmnster]
Loobed Offline
Loc: Northern California, USA
Yes you can. You can either just tap into one battery directly, or you can just use some resistors. I can't remember how to set up (calculate the correct ohms) the resistors. The simplest way is to get 2 resistors that are equal in ohms, connect them in series, then connect the positive and negative between 1 resistor. I am sure if you did a search on the internet you could find something. Also check ebay for a converter: You might be able to get one for $5.
Edited by Loobed (11/05/11 07:21 PM)
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#2426332 - 11/05/11 09:26 PM Re: Can I pull 12V from a 24V system? [Re: antonmnster]
Colt45ws Offline
Loc: Central Washington
Yes, you can tap off of one battery and get 12V. Thing to remember is to split the 12v load between the two batteries. If you run a wire from between the 2 batteries, use it as a ground, and use positive from the truck harness, you will get 12V. If you use it as a positive, and ground to the body/frame, you will get 12V.
Edited by Colt45ws (11/05/11 09:29 PM)
-Colton
2002 Ford Crown Vic PI, 182k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#2426481 - 11/06/11 04:47 AM Re: Can I pull 12V from a 24V system? [Re: Colt45ws]
eljefino Offline
Loc: ME
I would be concerned about the battery you tap not charging fully. (This would be remedied by at least a little time with the radio turned off.) Also if you tap between +12 and +24 for, say, a stereo, make sure the stereo chassis isn't grounded.
#2426589 - 11/06/11 08:37 AM Re: Can I pull 12V from a 24V system? [Re: antonmnster]
antonmnster Offline
Loc: Minneapolis
I'm thinking of just running a tap for just a charger/xmitter for my phone. I'd be drawing less than a watt. Shouldn't upset the battery balance!
There is an accessory plug in the cab, but I've never checked its voltage. I've always assumed it to be 24V, but I suppose it's possible the manufacturer added some resistors or a convertor.
Thanks for the info, fellas!
Edited by antonmnster (11/06/11 08:38 AM)
#2426796 - 11/06/11 12:56 PM Re: Can I pull 12V from a 24V system? [Re: antonmnster]
eljefino Offline
Loc: ME
Once you discharge that battery a little its internal resistance will drop and it will stay "happily" at ~85% charge instead of the 90-95% charge you usually get at float. So you could stick a manual 6 amp charger on the victim battery once a month for a few hours.
#2427381 - 11/07/11 07:33 AM Re: Can I pull 12V from a 24V system? [Re: antonmnster]
meep Offline
Loc: Southeast
an amp or two should be fine, as said above.
More than 5 amps I'd get nervous-- the "victim battery" will sit a little low and the other battery will run little high on V, lose fluid more rapidly.
The resistor idea only works for small, FIXED loads. And you'd need some hefty resistors = much heat and waste current if you wanted a so-so stable V to run a 5 amp head unit. Cheaper to find 24-12 converter somewhere... they have to be out there...
M
2006 Tundra 2wd
2002 MDX (wifey!)
2005 s60 2.4L
#2427763 - 11/07/11 03:07 PM Re: Can I pull 12V from a 24V system? [Re: antonmnster]
Cujet Offline
Loc: Jupiter, Florida
It's not likely you will experience any sort of problem.
We do this kind of thing with 48V golf carts. We use 3 of the batteries for a total of 24V for aircraft starting.
No issues, ever. Very long battery life.
However, I don't use the chassis ground. I use 2 dedicated wires.
Turbo's rule.
#2428056 - 11/07/11 07:02 PM Re: Can I pull 12V from a 24V system? [Re: antonmnster]
onion Offline
Loc: kansastan
OEM's do this sort of thing all the time with heavy equipment and buses. Just use the jumper between the two batteries as a 12=volt source. For what you're doing, it won't hurt a thing.
Now if you were to draw a high load (say, 20+ amps?) for hours at a time, then it MIGHT become an issue. The solution I've seen (from both bus and heavy equipment manufacturers) is to split up the 12V loads between the two batteries so that they're roughly equal. That method has been used for decades. John Deere did that with their diesel tractors in the 1960's, and lots of tour buses still supply multiple 12-V circuits off each battery.
The invisible and the imaginary look exactly the same.
#2428617 - 11/08/11 08:55 AM Re: Can I pull 12V from a 24V system? [Re: onion]
meep Offline
Loc: Southeast
^^^^ I like this post.^^^^ even if it's different from mine. reading it, this would put my mind at ease.
2006 Tundra 2wd
2002 MDX (wifey!)
2005 s60 2.4L
#2430002 - 11/09/11 02:33 PM Re: Can I pull 12V from a 24V system? [Re: onion]
PandaBear Offline
Loc: Silicon Valley
In theory, as long as you do not draw too much from one of the 12V only and never swap their roles once in a while to balance out the charge / wear, you should be fine.
If you are going to run it for a LONG time without some sort of swapping, or individually charge each of the 12V battery to keep their level matched, you may run into problem in the long run.
I'd not use resisters to divide the 24V down to 12V as they are not very good at regulating non constant loads. What about a separate 12V battery (even a very small one that isn't for automotive use) that you bring along and charge off the wall?
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#2430084 - 11/09/11 03:39 PM Re: Can I pull 12V from a 24V system? [Re: PandaBear]
eljefino Offline
Loc: ME
That would wear down kind of quickly in the cold, and deep cycling would be worse than the light discharge of a single 12v battery.
OP should run some tests, standing voltage at each battery when idle and when running, then again with his gizmos hooked up. Hundreths of a volt will count.
#2430227 - 11/09/11 06:28 PM Re: Can I pull 12V from a 24V system? [Re: eljefino]
antonmnster Offline
Loc: Minneapolis
In a couple of weeks when the unit comes out of storage and I'm on-site, I can test it out.
As an aside, I have to say that I'm really impressed at the depth of knowledge and helpfulness around here. The quality of discussions is so much higher than it is on, say, BMW boards.
Thanks!
