In a motor with very high mileage would there be any difference in power (pulling a steep hill) in cold weather (below freezing) between a 5w30, 5w40, 15w50 and a 5w50? Would there be much a change in mpg?
Common knowledge says to use a heaver oil for older motors but I have searched that the heavier oils leave a film in the cylinder and get burned off. IF so, would that extra oil in the cylinder mess up the fuel ratio and cause less power?
