My Dad has a Cub Cadet Tractor with the 20 Horsepower Engine.
He has the type of drain plug where you take the cap off and pull out this plastic piece, and then when you are done draining the oil you push the plastic piece back on and put the cap on.
The metal part of the drain plug that screws into the engine block keeps getting loose, I finally took the whole thing off since I did an oil change.
Do I use some plumbers tape which my Dad has, or do I use some Loctite.
