Hey Guys,
I registered for this forum after lurking for years because I need some advice from people who know their lubricants!
I have a 2004 F150 4x4 (New Body Style)and I'm changing the transfer case fluid at 67k.
I know that the original fill was Mercon ATF, which seems to be no longer available, and Mercon V is the new ATF. I also know that Ford states that Mercon V should not be used in transfer cases. Everyone knows that warning is printed on many Mercon V ATF bottles as well.
Ford has their XL-12 Transfer Case Fluid, which I've read on this forum is basically straight Mercon ATF, and this is the fluid that Ford recommends.
I'm sure that Ford's XL-12 is straight dinosaur oil, and even though it's what is recommended, I'd like something with a little more protection because I run all Redline fluids in my truck. My question is: Can I fill the transfer case with Redline D4 ATF or would that cause a problem?
I couldn't seem to find a straight answer on that searching the heck out of this forum and many others. I'm just looking for something a little better than the OEM fluid that won't "ruin" the transfer case. Also, some people have said that Mobil 1 makes a Mercon (not Mercon V) fluid, but I can't seem to find that as an alternative either. I still have no idea why Mercon V isn't spec'd for transfer cases either, that doesn't really make sense.
Thanks in advance!
Thanks in advance!
