It's generally accpeted in the Dmax community that 10 quarts is fine. (Makes for easy oil changes).
There is a BROAD range of acceptable oil level on the Dmax dipstick.
I use 10 qrts. Last year I ran an entire OCI with no top off. It took me from the top of the dipstick range to the bottom, which represents approximately 2 qrts of consumption. I'm sure it could go a bit lower, but the bottom of the dipstick range is the limit of my comfort zone. I never had one bad thing happen, and to the contrary, had another great UOA, even running 20% down on volume by the end of the OCI.
Overfilling an engine is nearly as bad as underfilling and engine. Overfilling can whip the oil with the crank and cause areation. However, I don't think 10.5 qrts is going to be so overfilled that it's a risk. Just let the level drop naturally and it'll be fine. One-half qrt only represents (approximately) 5% overfilled; that's nothing to panic over and not worth the effort to remove it.
Generally, just put in 10 qrts, keep the level above the bottom of the range, and your buddy will be fine.
Also, as this is more of a maintenance question than an HDEO question, I'm moving the thread.
