Originally Posted By: NutBuster
It's not a mechanical problem. It's a lack of lubrication. If your oil doesn't cling to the cylinder bores, some piston designs will tend to "twist" in the bore more than others, creating the slap.
older piston designs with long piston skirts only mask the lack of lubrication. It's unfortunate that some engineers are forced to compromise piston designs to compensate for it.
No, it isn't. Piston slap began happening when manufacturers went from hand-fitted bores and pistons to "bulk-fitted" bores and pistons where the block was bored and then pistons "from a bin" were fitted to it. Coated skirts were then added to eliminate the noise, as GM, with the very short pistons they used in the LSx engines was the most affected by this.
If it was a lack of lubrication, there would be an engine longevity problem. Since there is not, it isn't. And if it was a lack of lubrication, it would dissipate immediately as soon as the engine had oil pressure. It does not. It takes several minutes to go away, which is the time required for the piston to expand enough to silence it.
