Originally Posted By: leeharvey418
Originally Posted By: hattaresguy
Surprisingly the ride seems ok, so I can't complain.
What's the pressure set at? If your door placard calls for P-metric tires and you put LT-metric tires on it at the placard pressure, they'll probably ride better but they'll be pretty under-inflated in terms of the kind of pressure you should run in an LT-metric tire.
40 psi, but I can crank them up to 80 if I'm carrying heavy loads which I really don't. My truck only scales at like 4,500 pounds.
Even though my truck is a 1/2 ton truck, it is rated to carry 1,900 pounds, but whenever I do carry heavy I don't go very far for fast. If I did I'd crank the pressure up to 60-70 in the rears. Tires fail because of heat and going 30mph or less for a couple of miles just doesn't generate any heat.
