The issues are with temperatures AND moisture.
The GL4 and GL5 additive packages are the similar except in different concentrations. GL4 will do the same damage but take a little more time.
This is one reason why I push the 2-3yr/
I have no problem using GL5. Ford GT owners require it. Subaru required it. Its an FSM option with all my previous Nissans/Mazdas too.
GL4+ fluids are GL5 without the scary label.
