Yesterday I decided to "preflight" my snowblower in prep for the snow season. Basically, I just make sure it's got new oil, proper tire inflation, check belts and grease the auger zerk fittings.
After doing that stuff, I turned the choke on, set the throttle at "start", primed it five times and pulled the cord--it fired and started about half-way through the first pull! After running for about 10 seconds, I turned the choke off and it settled into a nice idle.
I hadn't started that snowblower since about late February--I'm always impressed with this little engine. . . .bring on the blizzards!
