Let me know what you folks think here:
Blackstone Labs
1999 3.8 V6 supercharged Grand Prix with 64,311 miles.
5,097 miles on oil.
AC Delco PF-52 longer filter than stock
Comments: Rob: Sorry it stook so long for you to receive your container. We have two more coming your way. The stroage didn't hurt anything. Wear looks okay in this sam;le. As you can see, your wear levels were all close to averages, which show typical wear fromthe super charged 3.8L after about 5000 miles on the oil. Only sisicon was high in your oil, and it may show the need to check or change the air filter. No moisture, fuel, or coolant was present in this sam;le. Insolubles were low showing great oil filtration. Looks good! Check out the air filter and check back to monitor.
Aluminum 3
chromium 2
iron 23
copper 23
lead 1
tin 0
molybdenum 55
nickel 2
manganese 0
silver 0
titanium 0
potassium 2
boron 142
silicon 31*
sodium 7
calcium 2749
magnesium 15
phosphorus 687
zinc 779
barium 0
Viscosity @ 210* is 61.5
Flashpoint 405*
Fuel Antifreeze 0.0
Water 0.0
Insoluables 0.2
Yes the K&N 12" cone styl was dirty and was cleaned after the report.
edit-fixed your copper number for you
[ March 01, 2005, 09:00 AM: Message edited by: Patman ]
Blackstone Labs
5,097 miles on oil.
Aluminum 3
chromium 2
iron 23
copper 23
lead 1
tin 0
molybdenum 55
nickel 2
manganese 0
silver 0
titanium 0
potassium 2
boron 142
silicon 31*
sodium 7
calcium 2749
magnesium 15
phosphorus 687
zinc 779
barium 0
Flashpoint 405*
Fuel Antifreeze 0.0
Water 0.0
Insoluables 0.2
