A_H, how much higher is the OP in your Z28 with the RL 5W-30 vs the 5W-30 M1 you used to run?
I saw about a 5psi increase in oil pressure at hot idle with the RL.
Thanks, so what is the actual hot OP in psi at idle and at high rev's with the RL vs M1?
Out on the track with the engine running about 235F coolant temperature, the M1 ran about 40 psi at the end of long straights at ~5000rpm. Under similar conditions, RL runs about 45 psi. My numbers are approximate because the pressure gauge only has markings of 20, 40, 60, and 80 psi. I used to fret about why my track cars have a hard time topping 40 psi oil pressure, but after years of seeing them survive, I've gotten more comfortable with it.
Is this the stock, in the cluster gauge, or an aftermarket unit?
