Our 2007 Was due for pads. I looked at all of my options including Motorcraft I could get at Wholesale. After much research I decided to order some Bendix CT-3 ceramic pad from Summit Racing. I did front and rear.
Cost wise these pads were the same as Premium Motorcraft pads at my cost.
I recieved my order and opened to inspect. packaging was really nice and All hardware was included and is high quality
Couple of weeks ago i did the work. At 90,000 miles the factory pads were pretty shot in the front and had maybe 20% in rear remaining.....Im proud of my wife for not killing the pads.
The 04-07 require new hub nuts so those were supplied by ford. I cut the rotors and the install of the pads were just perfect. Fit and finish of these pads were spot on and all of the hardware fit perfect with no issues.Also flushed and bled the system
I did my bed in of the pads and let my wife drive it for a couple of weeks. I did an in spection this morning and everything looks great. the pads are quiet, stopping power increased and dusting is much less. At this point i dont see why these pads wouldn't last aslong if not longer then the motorcraft pads.
If your in the market for some new pads i would highly reccomend checking out the Bendix CT-3 pads. I was so impressed i just ordered a set to have on hand for my next brake job on my 99.
This entire 4 wheel brake job cost just shy of $150.00
