I will soon be gaining the use of a Sephia 4 cyl automatic w/127 k.Seems to run well with one exception--when you are stopped at a stop light etc with the car in drive the car vibrates/shudders while idling.Idling in park this does not happen.This was the reason my stepdaughter stopped driving it.
I had her shift between gears while I had the hood up and watched the engine.There was about 3/4 inch travel of the engine while doing this.So apparently the engine mounts are good.
Could this be a tranny issue?I am pretty sure the trans has not been serviced.I am thinking of doing a flush and filter change in addition to the usual oil change and tune up that i do to each vehicle i get.
Any ideas or suggestions on this problem or any ideas for upgrdes during the tune up.
