Originally Posted By: Hokiefyd
Originally Posted By: AccordV6MN
Does anybody know how good the CR test in comparison to TR?
They often correlate pretty well. That is, a tire that rates very high in Consumer Reports' testing also scores very well if Tire Rack tests it, and vice versa. There are at least two reasons why this sometimes isn't the case, and doesn't necessarily indicate a problem with either testing regimes:
1) Tire Rack and Consumer Reports do not often test the same size tires, so you can get some variation in how tires perform depending on the size involved.
2) Secondly, and this is related to the first point above, some of the tires tested are OEM tires in a certain size. Take, for example, the Michelin Primacy MXV4. CR's tire test referenced above used the P215/60R16 size. In that particular size, the Michelin Primacy MXV4 is an OEM tire on some Nissan Altimas. Because this tire is OEM to Nissan, it can have different performance characteristics than the same model tire in, say, the P225/60R16 size, which is not an OEM size for that tire model.
The main problem I have with CR is not in their testing protocol, but in how they report the results. They have a 5-bubble system that gives you only a general idea of the relative performance differences between two tires. But even then, you don't really know how much different a full red circle is from a half red circle, or an open circle. You might have two tires, both with a full red circle for dry braking for example, and the difference in stopping distance might be 6 feet if that's the delta between best and worst for a full red circle in that test. But a third tire might score only a half red circle with a stopping distance that's 7 feet behind the best. So as a result, you are lead to believe that the difference is greater than it really is.
Accord Man,
If you click on the Prius link that I provided, and then the link to CR Test from there, CR explains exactely how they perform their tests, the size of tire that they use and how many miles they run the tires over time etc. It's a short read but, thouough
Hokiefyd,
I agree with you in regards to CR scoring system. I like the point system better from the TR than the bubble system from CR.
