Hello Folks:
My first post on this forum, though I have lurked for a year or two.
Anyway, a Blackstone oil analysis of my wife's Mercedes. Looks like her car likes the Motul. Car bought new by us. Very mild climate. 5,000 oil changes, always. Mobil 1 0w-40 for first 50k. Big 8.5 quart sump. Hengst air and oil filters.
2006 Mercedes Benz C230 Sport Sedan, M272 2.5L V6, 7-speed auto. This is the engine that has improperly heat treated balance shaft gears, which causes excessive wear and eventual failure. Requires engine removal and near total teardown to replace balance shafts. Based on the iron numbers it would seem that my wife's car is not having this problem.... I hope.
Scott
Code:
Motul X-Max 5W-40 Universal Averages
MI/HR on Oil 4,960
MI/HR on Unit 79,460
Sample Date 3/07/11
Make Up Oil Added 0
ALUMINUM 2 4
CHROMIUM 0 2
IRON 7 29
COPPER 2 4
LEAD 0 2
TIN 0 1
MOLYBDENUM 4 44
NICKEL 1 1
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 5 6
BORON 52 100
SILICON 2 5
SODIUM 6 5
CALCIUM 2056 2254
MAGNESIUM 17 169
PHOSPHORUS 849 872
ZINC 904 1013
BARIUM 0 0
cSt Viscosity @ 100°C 69.7
SUS Viscosity @ 210°F 12.87
Flashpoint in °F 395
Fuel %
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.1
TBN 5.1
Blackstone comments: We're not sure what your maintenance secret is, but you're getting great wear numbers from your Mercedes. Universal averages show what normal wear looks like from this engine after about 5,200 miles on the oil. Considering your oil run was almost that long, wear metals are reading wonderfully low, showing no problems in the works. The TBN is a measure of active additive in the oil, and a reading of 5.1 shows plenty of active additive remaining since 1.0 is too low. The viscosity read normally, and no contaminants were found. Overall, looks good.
Scott
Code:
MI/HR on Oil 4,960
Sample Date 3/07/11
Make Up Oil Added 0
ALUMINUM 2 4
CHROMIUM 0 2
IRON 7 29
COPPER 2 4
LEAD 0 2
TIN 0 1
MOLYBDENUM 4 44
NICKEL 1 1
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 5 6
BORON 52 100
SILICON 2 5
SODIUM 6 5
CALCIUM 2056 2254
MAGNESIUM 17 169
PHOSPHORUS 849 872
ZINC 904 1013
BARIUM 0 0
Fuel %
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.1
TBN 5.1
