My 2002 Toyota pick up's clutch(194400km) started to make a rattling sort of noise a few weeks ago when the clutch is engaged(foot off pedal) at idling and low rpm (below 2000rpm).
It seems to be getting worse and can be heard while driving at slow speeds below 2000rpm.
The clutch works fine, I tried spraying penetrating oil and also copper grease on the fork as best as could but that made no difference.
The noise goes away once the pedal is pressed down about half way.
Is this serious or can I continue to drive it like this?
